petnrdx
I see lots of people using "discriminator taps" on scanners here.
My question is are the old Maxtrac mobiles a useful choice for monitoring these control channels.
I am a radio tech, and know lots about repeaters (I have built or worked on hundreds) and I know enuf about trunking. ( I have used both Motorola and EDACS)
But, I have not had the need to use a scanner for control channel use, if I need to listen, I use one of my service monitors, or I program up a Maxtrac.
I recall several years ago a friend of mine that was into scanning was using one 800 scanner with disc output to "drive" the other scanner.
Are Maxtracs programmed to the control channels of any use?
Or is the way these are being used needing to be frequency agile?
I have several of these left over, and the only other use I have is for 900 mhz Ham repeater receivers.
