scannersnstuff
- Joined
- Mar 31, 2006
- Messages
- 1,952
are lmr/public safety radios compliant as marine radios ?. i don't want to stray off topic and debate the part about using them on land. i know those rules.
The Coast Guard routinely uses Motorola radios that have Part 90 acceptance on them but the labels don't actually indicate Part 80 acceptance. I guess they can get away with that as the Coast Guard is part of the DOD and is a branch of the military. Different rules apply.
thank you all for the overwhelming response. but this leave's me stymied. if a part 90 radio is compliant as a lmr, what interference is it going to cause in the marine radio band ?. or is this the question ?. i can understand not using a amateur radio for a lmr/marine radio. just saying.
Narrowband probably won't be an issue being received on a wideband radio (might sound like lower received volume), but a wideband radio may pop out of the narrowband radio's passband, especially on a radio that has tight digital filtering. The OP may be able to "buy" an override code in the programming software to open wideband. So, just a recommendation to ask before procuring. With a past employer, we had several small boats we used for river stuff. The boats used to have Midland VHF public safety radios on them, but were later transitioned to XTLs. Most of the time, these radios were kept on either dispatch or VHF-17. Sometimes on VHF-22A. The boats also had a (separate) VHF-FM marine radio and a CB.Nothing, really, except that almost all Part 90 radios built in the last few years will not do wide band FM (25KHz) out of the box. Since Marine VHF still uses wide band, this can be an issue.
Most commercial radios do have the capability to still do wideband, but it's not standard.
Of course narrow band FM will work just fine.
Other than that, it's just the type certification and the differences between the Part 90 rules and the Part 80 rules.
Probably. Look up "radio transmitter fingerprinting".That is rellly a question that has always puzzled me. If you are transmitting on an appropriate frequency, with an appropriate power level and all procedures and protocols are followed is it possible to determine what make/model of rig are you using?
n2nov;2450601 <<major snip>> There are plans said:The PROBLEM HERE is that part 80 tech specs have to be compliant with SOLAS tech specs which are set by international treaties. This would involve the IMO,the ITU, and probably would have to be done as part of a WARC.
Part The part 90 narrowbanding of the past few years only involved US domestic policy.
The FCC setting new US rules, no international treaty needed to be amended.
