Are Most People Here Dedicating A TalkGroup Zone For Hearing Everything On A Trunked System?
JASII
Memory Capacity
Right now, I have only programmed in the Wildcard Talkgroup on one sub-system in my area. For others that like to listen this way, are you dedicating a knob position for this? There is no longer a way to select monitor mode from the device itself, is there?
amys17
East Sparta, Ohio
I have a knob posituon in all my zones set to trunking tg monitor. It's for the Ohio Marc's system and I put in every tower in the state with their primary and secondary control channels. So now no matter where I travel I can listen.
fordcobra04
Montgomery County, Ohio
Not interested in hearing EVERY tg that comes across a site... Dont care what city bus is broken down, or that a guard in a jail needs a door unlocked. If youre in rural type county or a county that has a small amount of tgs, it would work fine. Not for a county like Montgomery.
N6ML
In the interest of actually answering the question :p .... AFAIK, dedicating a knob position (to either Trunking TG Monitor mode. or Trunking TG Scan with a wildcard group) is the only way.
sefrischling
Public Information Officer
New London, CT
Nope. I have absolutely no interest in monitoring any TGs other than the ones I programmed in for the local system and certainly not for the state system. I want to hear Dispatch and TAC only. I'd love to monitor two systems at once, but even with that, I only want to hear Dispatch and TAC.
DJ11DLN
Mudhole, IN
Seems like there was some talk at one point of the PPS eventually supporting library import? If so and it could be made a little more comprehensive (just played with it so far, don't have mine yet so I can't do much), that might be the answer to hearing a lot without hearing "everything."
Or maybe I just imagined reading that...if so disregard.
N6ML
PPS has some basic support for importing P25 trunked systems and talkgroups from RadioReference database CSV exports. If that's not what you mean by "library import", I don't know what that is :)
JASII
Memory Capacity
Just to follow iup on this a bit more, if you use TG Monitor, do you see the name of the Talk Group or just the TGID number?
I just added three talkgroups to my list, along with the All/Wildcard 65535 and the named talkgroups display, instead of the number. I am jujst curious if that is how TG Monitor behaves, too.
N6ML
Yes - if there's a group in the group list for the TG Monitor knob position, you'll see the alias instead of the group ID.
Hit_Factor
Saint Joseph, MI
If set to TG Monitor you don't need the 65535, take it out.
shadow925
San Diego, CA
I struggled with TG Monitor for a couple of days then found a simple way to set it up. Just copy one of your knob positions that contains the talkgroup IDs for what you usually monitor. Then change Receiving Mode to TG-Monitor. Now you'll be able to easily identify talkgroups that you don't usually monitor because they'll be the ones that have a number instead of the alias.
