Are Single Frequency Motorola Capacity Plus Systems Licensed As IG Or YG?
JASII
Memory Capacity
As posted above, do users of Motorola Capacity Plus systems typically license as:
IG - Industrial/Business Pool, Conventional or YG - Industrial/Business Pool, Trunked?
Floridarailfanning
Tennessee
The way I see it, IG would probably be fine since it's a single frequency and not real trunking. If future expandability is expected, YG would make sense.
Remington12G
GØT AES?
I've seen it both ways. Most single-site systems for small corporations use IG, our fleet, and rental systems in the area use YG.
Ideally it has to do with channel loading. A good frequency coordinator would probably go with YG so there would be some indication to other coordinators that may want to reuse the frequency in adjacent areas.
Then you may have radio shops setting up users on IG channels out of laziness and not wanting to put the effort into coordination/licensing.
From 90.7 "Definitions"
Conventional radio system. A method of operation in which one or more radio frequency channels are assigned to mobile and base stations but are not employed as a trunked group.
Trunked radio system. A radio system employing technology that provides the ability to search two or more available communications paths and automatically assigns an open communications path to a user.
