I am currently in the process of getting involved with ARES here in CT and I want to make sure that I have adequate gear for field operation. I have a Technicians class license. I guess the easiest way to do this is I'll list off what I have so far and you can tell me what I am missing and/or should/need to have. Note: Money doesn't grow on trees, if you suggest any gear, please only do so if it costs under $500. Anything over that and I'll assume that you'll be lending me a couple bucks
My current Mobile rig:
-Icom IC2300H 2m
-Tram NMO antenna mount
-Laird NMO 2m antenna (the $10 one.. soon to be upgraded)
-Uniden Bearcat BC255N scanner.
Current Handhelds:
-Baofeng UV-5R+
-Radioshack Pro-651
-Motorola GMRS/FRS Talkabouts
Other gear:
-12v DC portable power bank. I built it myself and it consists of everything I need for "off grid" or down grid power of my equipment.
-20' portable antenna mast with Laird Tech mobile to base antenna adapter kit. (work in progress, just started building it on Sunday but weather has been crummy since.)
-Pelican case for storing radios and stuff.
Buying in the near future/considering buying:
-Kenwood V71A
-50' Feed line. Not sure which type to go with. This will be for connecting the antenna on the 20' mast to the transceiver.
-Browning BR-180 2m/70cm antenna. This will be mounted on that mast.
-Discone scanner antenna. Will be also mounted on the mast.
Any help is appreciated.
Thanks.
-Icom IC2300H 2m
Current Handhelds:
-Baofeng UV-5R+
-Radioshack Pro-651
Other gear:
-Kenwood V71A
Thanks.
