ARINC
DickS
Local ARINC "Company Freqs" on 128.67 mc to 132.05 mc seem to have disappeared entirely here in the Seattle/KSEA area. This happened in the last few months. Is it all on my end or something nationwide?
joeuser
The Wretched
North Central Kansas
Not nationwide, I got traffic this morning. Quite a few last week. Kansas here...
ATCTech
Central Halton County, Ontario Canada
Are the frequencies in question actually all licensed to ARINC, or are you calling all company ops frequencies ARINC as a generic name? The reason I ask is that it is possible that ARINC-owned services have changed frequencies, perhaps to the 136-137 MHz section of the VHF air band, but it is highly unlikely that every company operations frequency including those not licensed to ARINC all relocated.
Can you change your location for a while and see if hear anything you used to receive? Can you hear ACARS bursts in that same span, 131.550 etc.,or airborne aircraft talking in the same range to help determine if you're being blocked by spurious RF from another source perhaps? You'll have to take it one step at a time... that's what make the hobby so interesting! It might be a mystery now but it will be perfectly logical when discover what's changed.
Bob
ChrisP
Portland, OR
Yes, be sure and look at the 136 - 137 MHz range as ARINC and airline company channels are licensed in those frequencies as well. But I can tell you the 128.875 to 132.0 ARINC channels are still in use down here in Portland.
- Chris
ChrisP
Portland, OR
Just FYI, I've been hearing Horizon flights inbound to Seattle calling "Seattle Ops" on 130.7250 MHz all the time…
- Chris
AirScan
I want to see if I can p/u ARINC in San Diego. Anyone know what they are?
You can find the frequencies here, just search the frequency range 129.000-131.975 or 136.00-137.975
License Search - Geographic Search
From what I've seen these "Company" frequencies in this range are either owned by ARINC or Aviation Spectrum Resources Inc. Unfortunately in the case of Aviation Spectrum Resources it doesn't list who actually operates them.
ASRI.aero: Aviation Spectrum Resources, Inc.
Keep in mind a lot of the ARINC frequencies will be for ACARS datalink.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If the freq is between 128.525 and 132.0, or in the 136-137 Mhz range, the answer is yes. The DB marks this as Airline Ops, I'm sure, because it's more descriptive to a newcomer. S/he wouldn't necessarily understand 'ARINC / SITA frequencies'
Mike
DickS
Thanks. The mystery continues here. I can still hear and decode Seattle ACARS on 131.55 and 131.025. I can also hear and decode the Canadian ACARS on 131.475. Seattle Center on 127.05, 128.5, 134.95 etc. are still Q5 copy. Also I have had no joy searching on 136.0 to 137.975 either.
Thanks to you guys I'll stop thinking that they all went to p-25 or another freq. I might just have a herd of rogue itinerant spurs in the neighborhood.
Bob is right. This is an interesting hobby.
AirScan
DaveNF2G,
Define "a lot." There are fewer than a dozen ACARS channels out of all that spectrum.
I see there is some confusion in the thread with using "ARINC" as a generic term for all company frequencies. I meant the actual ARINC (Aeronautical Radio Incorporated) frequencies specifically and not the whole spectrum.
Although just now browsing the FCC database it looks like most/all ? the ARINC "owned" ACARS frequency licences have been cancelled. Did ARINC outsource their ACARS network to someone else ? (It's been awhile since I've monitored ACARS).
D
DaveNF2G
Guest
What he said. There are some who insist that ASRI only operates the HFDL network on shortwave, but a check of the FCC database shows that this is patently false.
Very few "company" frequencies in the 128.8 to 132.0 and 136 to 137.975 ranges are licensed to airlines. Calling them ARINC frequencies is pretty accurate for most purposes.
With respect to terminal operation frequencies on the ground (outside the aircraft band), some are licensed to ARINC and some are licensed to the airlines.
novascotian
Halifax, Nova Scotia
Just as a point of interest, here in Canada the airlines operate their own vhf ops frequencies. Yes there are a few ARINC sites but not many and really I cannot recall ever hearing anything on their frequency in this region. Here in Halifax, which is not a large airport by US standards, there are several company frequencies for Air Canada, Jazz, WestJet, FedEx, Air St Pierre, and as well the local agents for the several US airlines that fly into here.
Even the long distance HF stuff is not ARINC.. Gander Radio, which oversees the northwestern part of the Atlantic is operated by NavCanada, the ATC agency of Canada, unlike just south where New York Radio is ARINC.
kcoleman
Tallassee, AL
Just a Suggestion
If your up to doing the research, I find FBOs in my area can at times be of interest. Using AirNav.com, I've researched airports that are within 150-200 miles from my location. I plugged in KOAK in AirNav and going to the bottom of that page, it will list any available FBOs for that airport.
- KAISERAIR - 131.725
- LANDMARK AVIATION - 130.575
I've put together a decent list of FBO frequencies for my area using this method. Also include 122.950 as that seems to be a common frequency used at smaller airports.
Hope that gives some ideas, and good luck,
Keith
