Arlington County FD
RS8
Winchester Virginia
Programmed in the new Arlington system and do not pickup anythin.
Is this a P-25 system?
How should it be programmed in a BCT 996T?
RS8
Winchester Virginia
Arlington FD
Thanks for the suggestion.Checked everything but still nothing.
Entered the system as Motorola Type II/P25 and then as a P25 system. The frequencies are correct.Did I enter the system wrong?
mike_s104
Berkeley Co. WV/ Loudoun Co. VA
It might be worth it for you to get a premium subscription and just import it from the RRDB into FreeScan.
AE6QE
Austin, TX
I echo Mike's idea. I did that for my PRO-197 and PRO-106 using Win500, and get Arlington just fine.
My only other idea, is make sure that you are not mixing the older frequencies, talkgroups, or other settings from the old system with the new P25 system.
Feel free to bounce ideas off of me if you want. I don't speak "Uniden", but the settings ought to be the same for both brands of radios (although maybe inputted differently)
