Arrestors: 90V vs 600V
GenreLab
I'm trying to learn the performance difference between a 90v gas cartridge and a 600v in lightning arrestors. Can someone give it to me in layman's terms? I'm a newbie. Thanks in advance.
prcguy
90 volts across 50 ohms would be 162 watts and 600 volts across 50 ohms would be 7200 watts. Into a higher impedance the voltage will go higher, so the 90 volt version would be for very low power or receive only and the 600 volt version might be used for full legal limit power. You never want the gas tube to fire when your transmitting but you want it to be useful to shunt high voltage from lightning.
GenreLab
Thanks a bunch!
