Asheville biltmore Square mall
yardbird
Concord, NC
Try this?
Biltmore Square Mall
Transmit: 456.8625 Mhz.
Receive: 451.8625 Mhz.
Asheville Mall
Transmit: 468.850 Mhz.
Receive: 463.850 Mhz.
Transmit: 466.850 Mhz.
Receive: 461.850 Mhz.
Hope this helps
David
INDY72
Indianapolis, IN
Not sure on that one. But I remember listening to the Security Officers doing parking lot patrols, and walking beats thru the mall.
robkermit
Bakersville, NC
Jake, might want to take your scanner and sit at one of the tables for a couple of hours and enable Close Call ....
You may also want to program in the "DOT" simplex frequencies to your scanner, a lot of department stores use them since they only have a small handful of people using radios and so they don't have to deal with the FCC red tape.
robkermit
Bakersville, NC
Low Power & Itinerant Frequencies
Common Commercial Frequencies / Color Code (Industry Standard) &
GMRS (General Mobil Radio Service)
FREQUENCY COLOR CODE STATUS
027.4900 Business (Low Power) / (Itinerant)
027.5100 Business (Low Power)
027.5530 Business (Low Power)
30.84000 Business (Low Power)
33.12000 Business (Low Power) (.5 watt)
33.14000 Business (Low Power)
33.40000 Business (Low Power)
35.02000 Business (Low Power)
35.04000 Itinerant Business
42.98000 Business (Low Power)
43.04000 Itinerant Business (Special Industrial)
151.5050 Itinerant Business (Special Industrial)
151.6250 Red Dot Commercial Use, Mobile VHF (Common) / (Itinerant)
151.9550 Purple Dot Commercial Use
154.5700 Blue Dot Commercial Use, Base VHF (Common) (Low Power)
154.6000 Green Dot Commercial Use, Base VHF (Common) (Low Power)
158.4000 Itinerant Business (Special Industrial)
451.8000/456.8 Itinerant Business (Special Industrial)
457.5250 Business (Low Power)
457.5500 Business (Low Power)
457.5750 Business (Low Power)
457.6000 Business (Low Power)
462.5500 GMRS
462.5625 GMRS - Low Power Simplex
462.5750 White Dot GMRS, Non-Commercial Use
462.5875 GMRS - Low Power Simplex
462.6000 GMRS
462.6125 GMRS - Low Power Simplex
462.6250 Black Dot GMRS, Non-Commercial Use
462.6375 GMRS - Low Power Simplex
462.6500 GMRS
462.6625 GMRS - Low Power Simplex
462.6750 Orange Dot GMRS, Non-Commercial (Emergency Use or Travel
Info Only)
462.6875 GMRS - Low Power Simplex
462.7000 GMRS
462.7125 GMRS - Low Power Simplex
462.7250 GMRS
464.5000/469.50 Brown Dot Commercial Use, Mobile UHF / (Itinerant)
464.5500/469.55 Yellow Dot Commercial Use, Mobile UHF / (Itinerant)
467.7500 Business (Low Power)
467.7625 “J” Dot Business (Low Power)
467.7750 Business (Low Power)
467.8000 Business (Low Power)
467.8125 “K” Dot Business (Low Power)
467.8250 Business (Low Power)
467.8500 Silver Star Commercial Use, Base UHF (Low Power)
467.8750 Gold Star Commercial Use, Base UHF (Low Power)
467.9000 Red Star Commercial Use, Base UHF (Low Power)
467.9250 Blue Star Commercial Use, Base UHF (Low Power)
robkermit
Bakersville, NC
You are welcome. :)
By the way, I can confirm that a lot of department stores use the Red and Blue dot frequencies. Some use the GMRS/FRS bubble pack radios.
The Wal-Mart in my local town uses the Blue Dot frequency in their radios.
As always, your mileage may vary.
robkermit
Bakersville, NC
I am not familiar with the home patrol scanners. I have a 396T. I can tell you that unless you are very close to a store (or inside it) most times you will not pick up what is going on, simply because the walls blocks the signal from leaving the building. The people using walkies are transmitting at low power. I have a hard time picking up what is going on inside my local Walmart from the parking lot but no problem picking up inside the store.
From the looks of it, the Asheville Mall has a repeater in place to extend coverage, but I'm sure that it too is low power and probably can't be picked up very far once you get out of the mall parking lot. I wouldn't be surprised if the entire repeater system wasn't indoors.
I would say your safest bet for picking up mall traffic would be to monitor inside the building orbbe sitting in the mall parking lot. Outside of that I doubt you will pick up much.
