With multiband radios on multiple systems I want to know how “open” an ASK key can be? There will be times when all Keys will not be available and sometimes when no keys are available in the field.
Primarily conventional frequencies will be added/altered in the field without any ASK (dongle) available. It would be nice to be able to build or alter zones onTRS system without dongle (not a deal breaker), or at maximum enter talk groups (within allowed range). The question is can ASK keys be made to allow this level of programming without using dongle? If the various TRS systems were locked down it would be OK (only if Ask for specific trs is needed to alter that system and not a ASK for every system in the radio even though they won’t be touched) everything else in the radio could be field programmed without any keys in hand. If a trs is removed later, will it and it’s ASK leave any trace behind that could limit full use of the radio? My nearest COMT wasn’t sure, he’s always had keys in hand for the 2 systems he uses and follows a check list. He’s never “removed” a system.
