Asking for a little help with CLP1040
lendaddy
I'm sure this is one of the least sexy topics on here, but I'm going crazy with this. I work for a company that has several frequencies registered through the FCC for our multi-building factory complex. I was issued a gigantic radio to wear/use and it's always getting caught on things.
I saw the tiny CLP series in an ad one night so I ordered it thinking it would be a great fit. When I got it I realized I had to upload our frequencies so I ordered the programming cable and the installed the Motorola CPS software. Well now I can't find where in the software to enter my custom frequency. I can pick from 90 or factory installed frequencies but I can't see any custom options. Can anyone help? It would be much appreciated as I'm going nuts here :)
KG4INW
Midlothian, VA
Sorry to say but that's all that can be done with those limited radios. What radio do you have that you consider too big? Perhaps we can offer an alternative that'll work better.
lendaddy
Ugh, that's terrible new but I appreciate your taking the time to respond. I can't even send this thing off for reprogramming? Even the literature says it supports custom frequencies though...
KG4INW
Midlothian, VA
No problem. By custom it really means from the list of 90 predefined frequencies. I believe they can be set up to use a repeater but only if the input and output fall on one of those freqs.
lendaddy
No problem. By custom it really means from the list of 90 predefined frequencies. I believe they can be set up to use a repeater but only if the input and output fall on one of the those freqs.
At this point I'm $300 plus into this ordeal... how much would a repeater set me back?
KG4INW
Midlothian, VA
A repeater is infrastructure, used to extend usable range. A proper one with all necessary equipment costs several thousand dollars and needs to be installed in a logical location. Your employer might already have one or more since you said it's a large industrial area and you use Kenwood TK-360s.
lendaddy
It sounds like I'm in a bad spot.What really upsets me is that I actually called Motorola Solutions support and he assured me I could setup custom frequencies. Ughh...I should have learned during my municipal experience with Motorola Solutions not to trust them.
WA0CBW
Shawnee Kansas (Kansas City)
Yes, it can be programmed with a custom frequency but you have to remove one of the existing frequencies. Call Motorola and they can create a custom file for your particular frequency. Our shop does it all the time. Not sure if they will send it to an individual. You may have to go through a Motorola shop.
lendaddy
Great news, thx. I will look into that!!!
KG4INW
Midlothian, VA
Ah, that would be very good. I wonder why they'd make it so difficult though when most of their other radios are simply programmed with simple CPS. Not very flexible.
lendaddy
I have yet to hear back from Motorola (never have had great luck there). You had mentioned that your shop does this type of thing and I'm not sure if you mean your personal shop or a shop that you use. Either way, would you/they be willing to help me with this file? I would gladly pay a fee/make a donation. Thanks much!
lendaddy
Quick update, I just got off the phone with CPS support at Motorola. They were fantastic, took my info and e-mailed me my file in 5 minutes. Programmed like a dream... very impressed. I take back my earlier Motorola comments regarding support, well almost :)
Thanks to you guys as well, I was about ready to give up. Much appreciated !!!!
