Asp & Pro96
Ghost4658
Mayflower Ar.
I have pro96 and i live in Mayflower, so I get the Gold Creek tower for ASP and my scanner hangs sometimes on Gold Creek tower & ID 00001 ASP Disp. North that is the ID I listen to most.
But when it hangs there is no noise.
And i can push scan and it will go on scanning.
This may happen 4 or 5 times a day.
I unhook the ant and it will not unhang but I am so close to the tower I can pick it up without an ant. so I don't know if it is a birdie or not.
I have tryed turning my squelch full to the right and it dont help.
Any one out there have any anwser to the problem?
Any one out there haveing the same problem?
aka
It sounds like your Pro-96 is malfunctioning.
I would try traveling to another tower site and monitoring it (at approx the same distance that you live from your local tower) and see if you can duplicate the problem.
Does this happen on other systems? I had a similar problem on an analog system using a Pro-97.
Ghost4658
Mayflower Ar.
Only on the Gold Creek tower and only on ID# 00001 ASP Disp. North.
ATT dont' help.
It don't happen on any other systen.
It only happens 2 or 3 thime a day, so I don't know it must be a birdie channel.
safetyobc
South Arkansas
ATT dont' help.
I read somewhere on these forums that a certain frequency in the 800 MHz had a birdie on it on the Pro96 and was causing a similar problem.
