rbritton1201
Captain1201
- Joined
- Jul 27, 2020
- Messages
- 407
- Reaction score
- 81
When I attempt to do it via Sentinel, I can't seem to make the digits I enter via Sentinel to work when punching in the sequence to access a channel NUMBER within a Favorites List. Eventually, I just used the direct entry method by entering the information right into the scanner itself. Only then was I was able to get numbers to associated properly with Favorites Lists Channels. I could never find a concise explanation in any manual, including Mark's Scanners, or via You Tube, that demonstrated exactly where the entries are to be made to assign digits to assign NUMBERS to Favorites Lists/Channels within Sentinel. I think the confusion is caused by the way in which tabs are labeled within Sentinel, ie: Favorites Lists, Systems, Departments, Sites, Options, etc...With tabs entitled SITES and OPTIONS, it's confusing to know what to enter in those areas. The tabs don't resemble the conciseness of the direct entry method, where SITES and OPTIONS aren't even included as a selection category but seem to be sub-categories of other tabs.
The direct entry method uses the following sequence, and it works fine:
Press MENU
Press MANAGE FAVORITES
SELECT FAVORITES LIST
Press REVIEW EDIT SYSTEM
CHOOSE SYSTEM
Press EDIT DEPARTMENT
CHOOSE DEPARTMENT
Press EDIT CHANNEL
CHOOSE CHANNEL
Press SET CHANNEL TAG NUMBER
CHOOSE NUMBER
PRESS E BUTTON TO STORE
Does anybody know, from Start to Finish, how to program digits via the Sentinel program to assign NUMBERS to Favorites List channels that uses a straight forward progression like the direct entry method above?
Press MENU
CHOOSE SYSTEM
CHOOSE DEPARTMENT
Press EDIT CHANNEL
CHOOSE CHANNEL
CHOOSE NUMBER
