JamesPrine
Hello all!
I'm having some difficulties programming Entergy frequencies into my PRO-433.
I've programmed all three frequencies listed for the Ponchatoula area into my PRO-433 via ARC433 programming software. I applied the appropriate settings for Motorola Type II trunking, and now is where it becomes interesting...
Should I apply Status Bit on or off?
For the End Code, should I select Ignore, or Detect?
For the Control Channel setting, it offers OFF, or Plans 1 through 4...which should I select?
I am getting a lot of traffic on the Entergy frequencies on my old PRO-92 scanner that I programmed with Win92, so the frequencies are indeed very active.
I used ARC433 to set up LT settings for North Oaks Medical Center and it works perfectly, by the way.
Any assistance or advice is gratefully accepted!
73
James
73
James
