astro 25 mobile cps r20.01 scan list problem
paul612
mass
Question. Odd issue with astro 25 r20.01.00 no matter what code plug I open vhf/UHF or 800 for xtl radios I can not modify the scan lists. The glasses pop up. And these codeplugs were fine previously. I've even reinstalled the cps and same results. I'm running xp on a tough book.
sfd119
Looks like your Zone and Channel is hidden. Right click on the blank space to the right of Channel Text and select "Unhide". Unhide everything in there.
paul612
mass
Ok. I've done that and I can now edit what is there but I still can not add or delete channels from the scan list. I have never had to anime any columns for this to work.
sfd119
What do you mean you can't edit scan lists? On the radio itself or inside CPS? Right there is the scan list. Are you saying you have no options on there to add/remove??
You need to be a little more specific if you want help.
paul612
mass
Don't know how much more specific I can be? I posted a pic of the cps. The scan list add and delete buttons are greyed out. They shouldn't be. Therefore I can not edit the scan list in cps.
sfd119
The first picture you posted normally has the eye glasses there under the Zone and Channel texts. Unhiding the two things I requested should allow you to edit the channels in the scan list.
If you could, post an updated picture with the issue with what I requested to be done.
If you desire a channel or two gone scroll all the eay to top of the zone section menu and select unassigned in that tab on far left of the tab you just unhid.
W4KRR
Coconut Creek, FL
I think what the OP means is, in the list for Zone Channel Assignments, under the "Channels" tab, there are icons on the top of the list to "Add Record to end of Table", and "Delete Current record from Table". These icons are greyed out, you cannot add or delete any channels from the Zone Channel Assignments list.
