ASTRO CPS Mixed Mode Help
rr60
KVL 7000
Hey there, I hope someone has the answer to this problem.
Radio XTL 1500 Conventional ASTRO
I can enable mixed mode on the RX side of the radio and it
decodes digital and analog just fine.
The radio however transmits ASTRO digital.
I would like to make a mode RX both digital and analog (which it does)
and TX Analog (can I get it to TX Analog?)
As a side note the software has a snafu for the 1500 that
took a long time to figue out. Enabling buttons for scan
are found under microphone settings!
Also the XTL 1500 can't do User Program Scan but can do fixed.
Thanks for your input.
FuelForFire
The Garden State
r60 said:
HI would like to make a mode RX both digital and analog (which it does)
This is selected on a per channel basis. Just select mixed for recieve mode and analog for the transmit for whatever channels you want this applied to.
Mike
