Astro Digital Trunking
NuclearDoctor
Delran
Ok, we wanted to hook an Astro Digital Trunking System up to our speaker system in our engine bay but we don't see a speaker output on the Astro by Motorola. Does anyone know how to do this or the best way to?
ResQguy
Meh
If it doesn't have a speaker, how does it work at all? Could you clarify what kind of radio this is?
NuclearDoctor
Delran
Its a Motorola Astro, its the achually base unit that you use to talk and hear with. It has a built in speaker, I don't see any outputs on it.
Please post the exact model number. "Astro" refers to a whole line of products. There may be a connector on the back to provide external audio.
mikewazowski
Staff member
Central Ontario
He's probably looking for a headphone or external speaker jack which doesn't exist.
You should be able to hook something up to the connector on the back of the radio using the appropriate outputs. Just be careful not to ground them or you'll blow the audio amp.
Perhaps you'd be better off calling in the local two way shop to do the job for you instead of risking damage to the radio.
grem467
Houston, TX
i would HIGHLY recommend you call whoever maintains your radio system and have them offer a solution/tech to do this. That consolette is extremely expensive and someone wouldnt be happy about damage to it. it is VERY easy to blow the audio amp in it if you are not careful.
NuclearDoctor
Delran
Yea but its alot of money to have someone come out and do it thats why we were trying to find directions on how to do it.
SLWilson
Ohio
15 pin connector.....
You "shouldn't" have to have PAY anyone come out & hook it up.....Just call the motorola shop, tell them you need one of the 15 pin connectors that plugs into the back of the radio that THEY will set up for you to run an EXTERNAL speaker. They should send it to you for about $5.oo bucks. You wire up your speaker leads to the two wires they left sticking out of the plug, and, away you go!!!!
We have one hooked up to our Zetron radio console that way.....
Steve/KB8FAR
