Astro Saber 800Mhz VSELP
BRIAN99
HAMILTON NJ
Hello:
Does anyone no if an Astro Saber111 VSELP radio from an abandoned Vselp system in Memphis work to receive a VSELP system currently in use in Trenton N.J.?
Brian
mancow
N.E. Kansas
Yes, it should work. You would need to program the appropriate system into it but as for the digital VSELP voice decoding it should be fine.
Get it and program all the system channels in as conventional modes. At least that way you would know right off the bat if it will decode.
What if the particular radio he wants to buy was only used with analog talkgroups. Sure the system supported VSELP - but does this particular radio? He needs to get the radio's flashcode to comfirm this (and he needs to be asking this type of question on batlabs - no here).
mancow
N.E. Kansas
He mentioned getting a radio that was used with an abandoned VSELP system so I figured he meant that the radio interfaced with the system at some point in time. That's the way I read it anyway.
But, your points are all very true.
Brian99, you will want to check the model # and flash codes to make sure it actually does what it says it's supposed to and don't always rely on what's printed on the label.
I took this in context with his other recent posts relating to VSELP radios and a decommissioned system in Memphis. You can run analog radios on an Astro (but not Astro-25) system.
