ASTRO Saber: CHECKSUM Error
mfn002
Bryan, Texas
When I try to read an ASTR Saber II that I have, the RSS will begin to read the codeplug, but then stop and give me this "CHECKSUM" error. Is this fixable? More importantly, what does it mean?
bezking
On the Road
It means some part of the codeplug is corrupt. If you have a known good save file, try writing it straight into the radio without reading first.
mfn002
Bryan, Texas
Unfortunately, the only other one I have is for a Model I. I did try to load it, but I got the same error message. Making matters worse, I don't have a SmartRIB. I've been looking for one for years, but can't seem to find one. For further reference, the model number is H04SDF9PW7AN and the FLASHcode is 100004-00000-4. Also, the RSS is version number 09.05.00.
mfn002
Bryan, Texas
Oh, and one other thing. It doesn't seem to be any particular codeplug block number. When reading the radio, it once got up to block 11 before giving me the error message. Sometimes, it doesn't go past 1, yet other times it'll go past 6 or 7. It was read at some point, because the radio was set to factory defaults, with "Z1 CHAN 1" on the screen and no other channels programmed.
bezking
On the Road
What is the flashcode and software versions here? Are you actually using DOS-based RSS or are you using Windows CPS?`
mfn002
Bryan, Texas
I'm using DOS-based RSS 09.05.00, and the flashcode is 100004-00000-4. It was re-flashed, because the original label was covered with a new label with that flashcode on it.
mfn002
Bryan, Texas
Here's what the label says:
FLASHcode: 100004-000000-4
System Package: H37
Manufactured 8/4/2003
FFPM571
Chicago area
If your using a software that is probably too old. Astro software for Astro sabers latest version 5.03 It may have been programmed with CPS
mikewazowski
Staff member
Central Ontario
Are you running the RSS in a DOS box under Windows or are you booting directly to DOS to run it?
I don't believe the RSS unpacks and checks the codeplug until it's finished reading it so it's probably unlikely it's corrupt.
Sounds more like a communications problem then a codeplug problem.
mfn002
Bryan, Texas
I was running it in a window on a machine running Windows 3.1. I'll try running it in pure DOS mode. However, it seems unlikely that the RSS is the problem since the eBay seller was selling it as for "parts or repair". The listing also said that the radio was surplused because it couldn't be programmed. I got it thinking that it was something small, like the former owner not having the right RSS version.
mikewazowski
Staff member
Central Ontario
RSS doesn't like Windows.
You need to boot right into DOS to run it properly.
You can make codeplug changes in Windows but reading and writing to the radio are a definite no no.
mfn002
Bryan, Texas
Good news: codeplug read. Bad news: "Codeplug too new for this application." This is the second time I have tried to program an ASTRO Saber II or III and got this message.
mikewazowski
Staff member
Central Ontario
All it means is that the version of software used to program it last is newer than the version you've got.
Since you've got the last version of RSS that was produced before CPS was introduced, you'll have to make the jump to CPS.
mfn002
Bryan, Texas
Does Motorola still make the CPS for the ASTRO Saber?
bezking
On the Road
Part number RVN4182V ASTRO SABER XTS3000 CPS is showing available for $276 direct from Mot.
mfn002
Bryan, Texas
Dont need a smart rib to program them If you want to upgrade the firmware then you would.,
I know that, but I would like one because I was hoping to make the readable Model I that I have into a Model II or III, if that's how you do it.
SurgePGH
Gold Member
Belle Vernon, PA
+1! The Sabers are VERY choosy when it comes to reading or writing. Even the clock speed of the CPU affects weather or not it will be a good read and or write.
