ASTRO Saber: CHECKSUM Error
mikewazowski
Staff member
Forums Manager
Oot and Aboot
You're thinking of a Saber.
The Astro Saber has no problem with CPS or RSS when used in the proper DOS environment.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I know that, but I would like one because I was hoping to make the readable Model I that I have into a Model II or III, if that's how you do it.
No it's not.
You can use a normal rib, an s-record for the model you want and appropriate software.
mfn002
Bryan, Texas
No it's not.
I have a file for a Model I, but it gives me this "Codeplug does not match model number" error. Is there any way to create an entirely new codeplug that I could load into it?
bezking
On the Road
You can't just drop a Model III codeplug into Model I hardware, even if you added the display and keypad. The radio will still think it needs a Model I codeplug.
You fix this by using Depot or Lab, which you cannot get from Motorola, and you can't ask for it here. :)
mfn002
Bryan, Texas
No, no, no, no. That's not what I meant. What I wanted was a 09.05.00 Model II codeplug to write over the existing codeplug in the Model II.
bezking
On the Road
Even to create a new blank codeplug you need Lab or Depot.
You could check codeplugsupersite.com and see if there is anything there that could help you out...
