Astro saber firmware
rnemtb2
Tinton Falls, New Jersey
Good afternoon ,
is there an easy way yo find out what firmware version my radio has installed? I just purchased another one ,went to program it using cps and I get a message firmware needs to be updated.
thanks in advance
George
n3obl
Ø
PA
turn radio on and hit lower back side button five times will place radio in service mode where version will scroll across screen.
These radios require a smart rib and a OEM flash cable (Different than regular programming cable) to update the firmware.
Also most older pre 4.xx firmware radios are probably 512k vocons so they can only come up to 5.6 firmware. 1meg was 7.71xx
rnemtb2
Good morning ,
Thanks n3obl. it shows 04.01.05.00 . trying to find someone locally to update it, if possible. I went to program it . I get the message it won't take the 2.5khz transmit deviation firmware needs to be updated.
n3obl
Ø
PA
Thats old VSELP firmware. Probably wont do P25 digital. I do have the stuff to do it but would have to be shipped.
rnemtb2
Good morning,
I have yet to receive your pm. I have been busy with work so I have not had the chance to go further into this. I had firmware updated and did a drop and drag from one code plug to another. Everything transferred ,the only problem I have now is that one of my conventional personalities won’t receive on that channel and mdc and modat tones are only heard on receiving radio. I pulled up both code plugs and they look the same. All boxes are checked for tones to work including preamble and so I can hear tone before I speak. Power up tone is selected and is not heard when powering up. Thanks for your help it is appreciated.
n3obl
Ø
PA
Trying to find 7.71.08 file. Seems elusive.
ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO. NO.
It's been a while but I THINK that modat isn't supported in IMBE firmware, or at least in version 7+ firmware. In any event, modat is pretty much the ultimate description of useless these days. And it's very annoying. Do NOT be THAT GUY who transmits MODAT sequences. You will have NO friends if you do.
AESFTW
Correct
