Astro Spectra "bricked" error FL 43/82
gary123
I have successfully messed up my Astro Spectra. I loaded a bad codeplug into it. Now I get fl 43/82 ( sometype of EEprom error) followed by fl 01/90 (control head error). When I attempt to read or program the radio I get the communication with radio failed error and no ack/nac message. The rib box and cables are good.
I have good archives of the radio along with a good srecord. I have tried everything I can think of to get the radio to program but cant get past the no communication error. The internal eeprom may be the culprit, does anyone know how to eitehr blank it or force a file into it?
reveiwing what I did I may have loaded a none ASTRO codeplug to the radio. I have the file loaded to the radio.
gary123
Replacing the board is one option I am looking into. If there is some way to force the eeprom to take a file I could rescue the radio.
I have lloked closer at the file placed into the radio and think that since it isnt a proper Astro codeplug this is why I cannot communicate with the unit anymore.
mikewazowski
Staff member
Central Ontario
If the codeplug was improper or not the correct one for your radio, the CPS would have complained.
Sounds more like communications were messed up during programming.
About all you can do is get it to take a proper codeplug or force an s-record in.
If that doesn't work, then you are probably looking at board level repairs or a replacement vocon.
Sometimes you'll find good donor q split radios on eBay really cheap.
gary123
I have checked the file loaded and it is bad.
If I could get arround the no communication error I ahve all the materials nessessary to reload the srecords. It is looking more and more like its time to replace the vocon.
jparks29
John McClane
Nakatomi Plaza
sounds like someone screwing around with lab and not knowing what they're doing.
LOL @ 'field upgrades'..
gary123
Close but not quite correct. I selected the wrong file to load. One of these days I will learn how to read. LOL not upset just annoyed :)
