ASTRO Spectra no TX Audio
KK4LQX
Suffolk, VA
Hello All,
I recenetly picked up an ASTRO Spectra (Model No: T99DX+089_AST; ID No: D04KKF9PW5AN). I got it home and programmed it with a code plug I had in another radio that works beautifly. I then tried to key my local repeater and got nothing back. I then went to a repeater that did not use PL tones and it worked. I did notice that the radio is able to receive everything that gets programmed into it. I took the radio to a friends house and hooked it to their CSM and found that there was no TX audio or PL tones being generated and the radio puts out 45W. I then attempted to swap the VOCODER board from an 800 MHz radio I had lying around. The radio DID NOT like this at all and I sawpped them back. I then attemped an alignment using tuner and found that the RO was only like 27 Hz off frequency, but oddly it did not like to TX around the 150 MHz mark and a wierd whining noise could be heard (not sure where it was coming from but it was only on 150 and only while the radio was keyed).
Does anyone know what could cause this? I have the 800 MHz radio available for parts if needed.
Thank you all for your time and assistance
KK4LQX
Suffolk, VA
UPDATE: I attempted a command board swap from the same 800 MHz radio that I got the VOCON out of with no success.
Also, another (not new) symptom, I am unable to key the radio using the rear accessory port.
jim202
New Orleans region
Before you went and modified the channels in the radio, did you follow good radio tech practices and copy the codeplug for future use? The other common practice is to test the radio on the channels that came with the radio.
Failure to at least test the radio on the channels that radio came with is about as bad as you can get.
On a different note, there are a number of jumpers on the main board that effect both RX audio, TX audio and the PTT on the accessory connector. Some of the jumpers are on the top of the board and some are on the underside of the board.
It would be wise to obtain a manual on the radio before you dig yourself too far into a hole.
jim202
New Orleans region
KK4LQX
Suffolk, VA
Yes, I always keep a copy of the code plug as received for future use and have tested the radio with that code plug with no success. Also I do have every manual published for the ASTRO Spectra line downloaded directly from Motorola online.
