astro spectra p25 not working
australia
i got some uhf astro spectra they had encryiption modules fitted they have been removed the problem seem to be on tx another radio does not rx p25 on a low signal i was told to drop the mod balance by 10 this did solve the problem
my question is when the encryiption module was orignally fitted did the radio have a realigment and also if they are removed does it need realigment (i assume that with the fitting instruction for encryiption modules it would tell you if aligment is required)
i have some xts3000 that have had the encryiption modules removed and did not have to realign them they work perfect
thanks david
MattSR
Sydney, Australia
No. The crypto boards don't affect the alignment what so ever. You can pull them in and out as you please and it won't affect the tuning.
ausscan
AFAIK the radios attempt to log onto the network to listen in, and would need the appropriate programming from a system administrator of the GRN. I stand to be corrected as I have never done any serious research on getting anything but a scanner to track P25 Trunking networks.
