Astro Spectra VHF Stuck transmitting
njemt7212
NOVA
Hey Guys ,
Quick question , for some reason my Astro Spectra VHF 50 Watt Remote mount seems to be stuck transmitting. This is new , if I turn off and turn on the radio is fine recieving but as soon as I transmit it seems to get stuck transmitting and cannot change channels or perform any other function till I turn off and turn on again. Ideas ?
Thunderknight
Bletchley Park
I'm not familar with the Spectras, but I have seen some radios that will do that if they have a very high SWR. Can you try a different antenna and mount, or a dummy load?
g-buster
Homer Glen, Illinois 60491
Your unit might need to be jumpered differently. It could be going into emergency mode. The jumper settings can be found in Batlabs and maybe Repeaterbuilder.com
FFPM571
Nashvillle
When it does it unplug the mic. That will eliminate the mic. If not it may be a bad capacitor that is leaking and causing issue
