MSWIN IS a Motorola ASTRO-25 P-25 system. It is NOT like the older Type II systems. Type II systems are firstly, not pure P-25, and do not come in 700 MHz, or 380 MHz. The 380, and 700 systems are only available in true P-25 (9600 baud per second rate for TRS) The "official" Motorola name for these true P-25 systems is ASTRO-25. ASTRO refers to digital capable Motorola systems, and ASTRO-25 is Motorola's pure P-25 offerings.
If your scanner is not 700 MHz capable your out of luck trunk tracking it. If your scanner is not pure P-25 capable (PRO-96 and newer example), you wont be able to even monitor conventionally.
