Astro25 Software
rustyjw
I cannot get the Astro25 Software to install on Windows 10 or XP. I get a .NET Framework error message. It then goes through the install process then at the end says there was a critical failure.
Any suggestions?
Sent from my SM-G920V using Tapatalk
FFPM571
Nashvillle
windows 10 does not play well with Astro25 sometimes. Use compatibility mode for Windows 7 or earler
Project25_MASTR
There's stuff I can't tell you...
Texas
What version of CPS are you trying to use?
Windows 10 doesn't play nicely with Astro 25…it does fully support Windows 7 (both 64 and 32 bit) as well as XP. Likely, the .NET framework you require isn't on the install media. Try manually installing it (.NET 4.0 if memory serves correctly) and going from there.
