Good day,
I am programming my XTL-2500 and need some guidance with scan lists. As in a separate list for each zone.
Some pertinent information.
The radio was tested/tuned by a /\/\ technician and I have a good base code plug & copies to work with.
I have a valid copy of RVN4186AX
I have several conventional zones/modes programmed, & a separate scan list for each zone. The problem is, no matter which zone I go to it defaults to the first zone's scan list. The other lists are completely ignored.
All the conventional zones/modes have been programmed in personality 1.
In doing some looking, I found if I need to add P25 modes, a p25 personality needs to be added. Do I need to add a new personality for each zone (and add those modes to it) to get the scan list for that zone to actually work?
Thank you in advance.
