I have had an Anytone AT-5888UV for a while now, it was suggested by a friend. Please see my mini-review at Anytone - AT-5888 Mini Review
Recently my son bought what he thought was the same radio for his Jeep as he is an avid off-roader in the desert here. It turned out that he actually got an AT-5888UV III, very similar to the prior model but with some differences:
I used the "III" for a local net yesterday an hour after it arrived from Amazon and everyone said it sounded just fine.
One thing I have found that the speaker on the hand-mic actually sounds pretty darn good, I was pleasantly surprised.
I will probably get one of the "III" versions eventually to replace my trusty Alinco DR638 in the van. It has served me well but it is 9 years old and I am well past the 7-year itch.
- The "III" has 220 coverage for RX and TX
- The "III" has a much more bulky heatsink built into one side of the cover. This makes the radio noticeably heavier.
- The "III" has 2 speakers, one on the bottom and one on the top. (Which is the bottom or top is conditional, as the head is reversible.) The one on the aforementioned expanded heatsink side is assigned to the Sub-Band, the other to the Main Band.
- There are two different software packages ("QPS") for these radios available at Software & Manuals, one cannot read/write the other. I suspect there is model information in the codeplug. If I parsed it out with a text editor I suppose I could find it and edit it but there was no need for me to do so. (See below)
- I was unable to easily clone one radio to the other as the software packages were not compatible. I tried via Chirp and no go there. I did however find a workaround; The QPS for each radio supports Copy/Paste between them. I copied the freq and other info for the channels in the spreadsheet style channel programming from one radio and pasted it into the other. I tried to copy/paste in Chirp but it appears Chirp does not support that.
- The mics are identical and interchangeable. They also come with the same bracket and hardware.
- They use the same programming cable.
- While I did not try it I suspect the heads are probably swappable as well. The only difference I could see is the labeling on the "III" says "Tri-Band" vs. "Dual Band" on the older radio.
