Your truck brain is generating all that noise. Probably, the anti-lock brakes are reducing that noise.
You need a filter in the power cables close to the radio.
If your antenna does not have a DC ground path, a filter there may help or change to a type of antenna like base loaded with a DC ground path.
Air bags are another big offender for generating noise, as are the light bars.
I do have the LED fog lights. if you have LED head lights, try turning those on, see if anything changes.
I am using a Motorola 24-80371A05 coil with a 44" whip and very little noise.
Larsen NMO40C is nearly an exact replacement.
