ATCS Monitor for Windows
Grove City, Ohio
Good Day Folks!
Anybody here use the Advanced Train Control Systems Monitor (ATCS) for Windows? http://www.atcsmon.com/ I just started using the program and so far I have been having a lot of fun, there are some "live feeds" over the web, and with http://railroadradio.com you can hear and see where the trains are. have not had a chance to try it out in field yet. The link shows the recommended scanners that work with the application. You will need to install a discriminator tap for it to work. but the live feeds give you a chance to try it out from home.
trainman111
Richmond, VA
I use it. Mostly for the "live feeds" though because my setup isn't perfect enough yet in order to receive the BCP's from CSX.
radioscan
Radio Sensei
Southern Ohio
I've been using it for it for three years now, mostly in the field.
I did have a server for awhile watching the 11,000 foot Carlisle Siding
on the CSX Toldeo Sub, but that computer is off line for the moment.
I'm currently keeping an eye out for any new ATCS installations in the Cincinnati area.
W5JLF
D/FW Texas
Where do you get the program itself? I went to the ATCS web sit but did not see where to download the program.
Thanks Joe
radioscan
Radio Sensei
Southern Ohio
Pro-97
The Pro-97 is on sale at RS for $150 ($50 off) until June 23rd.
It is easy to modify with a discriminator tap and makes an excellent field scanner for ATCS monitoring.
D
DaveNF2G
Guest
Caveat for CSX railfans in New York State: CSX uses a proprietary data system in the 220 MHz band to do what ATCS does elsewhere. You won't be able to track CSX trains here.
D
DaveNF2G
Guest
Yes, they are running the experimental system in New York. I don't know if they've attempted to deploy it anywhere else yet.
trainman111
Richmond, VA
Interesting. I've read about that system. I can't remember what they call it but there was a long discussion about it on the ATCS Monitor Yahoo! Group. It'll be interesting to see if they expand that system beyond NYS or not. I sure hope they don't!
