Attention Database Moderators!
N1SQB
Somewhere On Earth
In the CT New Haven Ciounty database, in the city of New Haven, you have highlighted in green the New Haven Area Special Hazzards Team frequency 853.4125.. However, when you click on the callsign listed, it takes you to a city in another state, Stapleton Georgia not New Haven CT. The callsign is wrong. Just passing it along.
Manny
In the CT database, in the city of New Haven, you have highlighted in green the New Haven Area Special Hazzards Team. However, when you click on the callsign, it takes you to a city in another state, Stapleton Georgia not New Haven CT. The callsign is wrong. Just passing it along.
Manny
Submit to database and they will change it, changes are not made based on RR posts.
N1SQB
Somewhere On Earth
They dont need a post. Just go on the database, click on the callsign and they can see for themselves.
I don't know the correct callsign, just saw it was highlighted and decided to check it out. That is how I discovered it.
If you don't want to do it correctly don't complain when it isn't done
dave3825
Suffolk County NY
Nothing is going to happen unless somebody submits the correct callsign.
I dont know it but the current one should be taken down.
That's not how it works.
As stated, database admins only add change or delete things when a submission is made. You do not need to know the correct call sign to make a submission. You don't even need to be in the same state. Just make one that says the call sign is wrong. That's all you need to do.
N1SQB
Somewhere On Earth
First of all, let me set you straight since you like to make smart comments without knowing the facts.
I have NEVER had to submit anything for any reason. Therefore, when I posted here, I thought I was doing the right thing. I NEVER said I would NOT do it the right way since I thought this post would be the right way. Instead of making ignorant comments, state the correct way and point out the incorrect way and leave the nasty comments out.
Second, at no point did I state I was complaining. My OP ended with the phrase "just passing it along". I will repeat, I have NEVER had to submit anything on this site so this is new to me.
Take a lesson from dave3825. His way of explaining it without smart comments, is well explained and I appreciate.
Enough said!
