There definitely is a setting for your attenuator on that radio. And I'm not looking at any of my radios now, but my Uniden SDS100 shows on the number 4 key ATT. If I wanted to do attenuate a signal I was monitoring, or make it where I wasn't receiving it as well, I would press the Func (Function) button and then the 4 key and I would see ATT on the screen as it attenuated that channel/frequency.
You might have misunderstood what the manual says and that is understandable. But you definitely don't want to use the attenuator unless you're trying to weaken the reception of a signal or maybe get rid of some sort of interference on a frequency. If you look under the menu setting on your radio there is a global attenuation which will attenuate everything and an attenuation for just attenuating the channel / frequency you want to. You do have different options depending upon what part of the menu you are in. When you're editing the information or a frequency you have your delay, the option to use the attenuator, etc, etc. But most of the time you will not want to use attenuate on the radio. It will definitely decrease your chances of receiving a signal.
Brian
COMMSCAN
