Hey guys, recently set up a base scanner for a friend and he can't have anything mounted outside or on the roof. I gave him a Centerfire folded dipole antenna that I set up in his attic. This is the antenna:
It's tuned specifically for public safety bands in high VHF which is 90% of what he's listening to. There are a few things he gets in the 400's and they still come in, but probably not as well as they could. There is also a couple distant frequencies that come in weak (analog) and a digital frequency he'd like to get that comes in but it's broken and sounds very "digital" most of the time and it's hard to make out. Just slightly better reception would clear these up.
He's been looking at the OmniX antenna to see if it would improve reception. It's probably an overall better antenna then the dipole, but my worry is that it's wide-band so the stuff in the VHF-high range might actually come in worse then it does now with the tuned dipole. The stuff in the 400's might improve a bit, but the potential loss in VHF wouldn't be worth it.
Any advice here would be great. I use a dual-band diamond commercial grade vertical on my roof at my house and don't have much experience with trying to find an ideal dual band (VHF / UHF) antenna that would work well in an attic. But ideally that's what he'd want.
Thanks guys!
Folded Dipole Scanner Antennas
Now you can get the performance of a folded dipole without the expensive price tag. Our folded dipole scanner antennas provide a wider bandwidth than our standard dipole scanner antennas. They are …
centerfireantenna.com
Thanks guys!
