I'm wanting to set up a dual band J-Pole antennae (VHF/UHF). My preference would be to keep the antennae up in the attic rafters rather than mount the antennae outdoors. The indoor installation has a lot of advantages to me. I would use the antennae with a 50W mobile radio fixed to a 110AC/113.8VDC power supply. Maybe sometimes I would connect it to an HT.
However, I have one major concern with the effectiveness of this plan. My workshop where I intend to install the antennae is constructed of refrigerated warehouse panels. The panels are two sheets of steel with about 3'' of Styrofoam between them. These panels go around all 4 side of the shop and all the way up to the peak of the two gable ends. The roof is standard plywood deck covered by shingles.
Do you think the metal skins on the barn walls will serious impede the signal getting out of the building? Do you have any ideas on how to test to what degree the walls deter the transmissions? I don't have any test equipment - just a couple of radios.
Any ideas, thoughts, or suggestions?
