With outdoor space available, long ago I gave up totally on attic-loop antennas, but I tested again to give hope to those with no other choice.
I'll *try* to get to the point quickly ... maybe...
The two key points are:
1) Use a small vertical loop rather than a horizontal loop, either plain wire or a nice amplified commercial unit. Horizontal loops are a waste of time (20db or more loss on low frequencies compared to a small vertical loop.) The small vertical loop is obviously much easier to rotate, or in my case slighty relocate based on empirical listening tests.
2) Much of the so-called attic noise is really just "whole house" noise being transferred via the common-mode of your coax. Off-the-shelf coax chokes do great to be able to make the loop sing, rather than listen to "two" antennas at the same time (your loop and the unchoked coax)
Details:
The small vertical loop itself is a simple wire loop about 16 feet in total circumference shaped as a circle, square, triangle (acute or right-angle). It is fed to the coax anywhere on the bottom wire of the loop that is convenient. Being so small and so close to ground, the near omni pattern is just about the same - so use what is convenient to attach to in the cramped space. But don't attach to the top of the loop.
I had plenty of zip-cord available, so I tested (and modeled), and like it predicted, horizontal loops, even small ones take a major hit in gain being so close to the ground. So small vertical loops in all these shapes was tested and found to be superior in all cases.
The 16 foot total circumference is not that critical. If you have the space a few feet more or less is not a big deal. And since we're not transmitting into it, simple stand-offs from roof studs can be used - including just tacking them directly if you don't have stand-offs - but if you can stand them off, do so.
CHOKES
Absolutely necessary. My attic is like most others with power, cable/sat tv, doorbell, heating and air-conditioning units and ductings etc etc.
But what was once first a totally unusable antenna, was quieted by using TWO chokes just like I do with my outdoor antennas. One choke off a small jumper at the back of the receiver, and another one up near the loop feedpoint in the attic.
Example: A quick example would be the use of the common MFJ 915 inline coax choke. This would go near the back of the receiver. Up at the loop in the attic, a similar version, the MFJ 918 which has two wires coming out at one end makes it ideal for use up there.
Plug - You might just want to bring out the big guns right from the start. What I use are Myantennas CMC-0510-R chokes instead. Big improvement over the MFJ, especially if AM BCB and 160m are important. Most amateur radio chokes have weak choking impedance at 160 meters, and don't go down to 500 khz like the Myantennas cmc-0510-r do. To make the transition to the two wires of the loop easier, I adapt to a BNC red/black double-banana-jack, which are commonly used for multimeter connections.
Whatever you do, do NOT use any sort of "voltage balun" up near the loop to make the transition to coax, UNLESS you follow up with a choke. If you only have one choke available, then you can use any sort of "current balun" to help keep that coax feedline quiet. Absolute impedance matching is not critical - I use a 1:1, but if you have a 4:1 or even 9:1 available, try that too up top.
This antenna like my outdoor versions was inspired by KK5JY's work in this area:
Small Loop Antenna for HF Reception
But I can't emphasize this enough - without choking you are fighting a losing game not knowing if your loop is picking up noise, or if your coax braid is the culprit. In my case, I'd say 99% of the noise was my unchoked coax.
If you have an amplified loop in the attic, I'd be sure to also use a choke at the receiver end, to help make sure you aren't rotating the loop to try and null out your coax noise! See what I mean?
Operations:
Now that my feedline is properly choked and out of the equation, low and behold, the attic loop performs as it should. Bands sound normal, my S-meter isn't pegged, but YES, I am in a new rf neighborhood. New little gremlins are heard on various frequencies. When my heater motor kicks in, a brief S9 spike on the meter jumps up and back down. So maybe I'll try to relocate it a little bit.
Signal gain - despite the superior gain as compared to the horizontal loop, I am still under a roof which isn't totally opaque to rf. But now that the majority of noise is controlled, I CAN use my preamp, and crank the rf-gain down just a little bit to make it just right. This is very similar to my on-ground log and dog antennas.
I guess the moral of the story is not to give up. Choke your coax - at BOTH ends - before you assume that the attic is unusable.
Details:
CHOKES
Operations:
