EJB
20 + year membership
Mr. UniTrunker, I think your name is Rick:
I have tried numerous times to get your software to work on a few of the systems in my area.
I hooked it up again and wanted to see if it would work. I first got it to work without any problems on our provincial system below. I can get your program to work on many towers up to about 40 miles away, I get a good signal on my Pro 2045 tapped scanner.
Here is the system
Bell Fleetnet - Ontario Provincial Government Zone 1 Trunking System, Southwest Zone, Ontario - Scanner Frequencies
In our region (county), there is a new P25 system up and running, it is a APCO 25 system
Halton Region (Project 25) Trunking System, Halton Region, Ontario - Scanner Frequencies
The tower is close by, I can easily follow it on my Home Patrol (not extreme) scanner but when I feed the signal from my PRO 2045 to your program I get no signal i.e. health is 0.
I am going to try to attach some screen shots.
The first one is called Uni Trunker on Motorola System Charlton> As you can see, it works great!
The second attachement is what the screen looks like when I try to get it to "hear" a control channel for the new APCO P25 system.
It is called "Unitrunker trying to run on a APCO P25 system.
There is a good chance that I am doing something wrong, I have absolutely no tech schills but I dont know why when I start your program, and use one of the control channels for our provincial system it works great but when I supply the program with a P25 control channel, no go. It also wont work on a EDACS system that is line of sight from me.
Look, I would really appreciate any help you can provide for me.
Rick
Eric
Toronto area, Canada
Here is the system
Rick
Eric
