I just upgraded to FW 1.11.16, hoping the channel spacing glitch was fixed, but no.
The channel spacing glitch issue is this: the interval resets on 100 kHz increases which is absolutely wrong.
For example: Custom search 3, 15kHz spacing. Search from say 142.830 to 143 Mhz. Steps are:
142.830
142.845 Correct
142.860 Correct
142.875 Correct
142.890 Correct
142.900 Incorrect
Next step SHOULD be 142.905 but is instead
142.900 (WRONG).
If I scan in reverse, a valid channel of 142.725 gets missed.
142.830
142.815 Correct
142.800 Correct
142.790 Incorrect
142.775 Incorrect
142.760 Incorrect
142.745 Incorrect
142.730 Incorrect as 142.725 is a valid channel step and IC licensed, scanner would miss this on a custom search.
As a result, my searches get off track. I *could* use 5kHz stepping but why?
Can this please be addressed / explained?
Thank you!
142.830
142.845 Correct
142.860 Correct
142.875 Correct
142.890 Correct
142.900 Incorrect
142.900 (WRONG).
142.830
142.815 Correct
142.800 Correct
142.790 Incorrect
142.775 Incorrect
142.760 Incorrect
142.745 Incorrect
Thank you!
