Audio adapter for Harris XG-75
jcardani
Orlando, FL & Ocean City, NJ
Hi All,
Does anyone know if there is an audio adapter available that can attach to the radio that will allow audio to be output on a 1/8" (3.5mm) jack so I can record from the radio? I've seen a version with a jack but it has several prongs. I am looking for an audio jack to plug a cable into it.
thanks
Joe
FDRadioguy777
The easiest way to do what you want is use the audio jack on a speaker mic. You will need an adapter to bring the size up to 3.5mm but those adapters are very cheap. Hope this helps.
