Audio Bandpass Adjustment Unitrunker
S
screamin72
Guest
I am asking if there is a way to eliminate the 97.3hz site connect tone. I hear it on all frequencies on OKWIN Motorola system. It sounds like a low pitch rumble noise. Using 2 R820T Mini's I can load the radios into HDSDR and usually eliminate it by narrowing the audio bandwidth from the left side by moving the red line to the right just enough to make the 97.3 hz site connect tone disappear (bottom right display). How is this done in Unitrunker?
(My Logitech Z313 2.1 desktop speakers are very sensitive to the low frequencies)
A note of praise good job Unitrunker for the custom alert sounds for Annunciation. I used CALL on a talk group using the 'whoop' sound!
krokus
Southeastern Michigan
You are hoping to have the filter become a part of Unitrunker, or would a separate filter be acceptable?
Sent via Tapatalk
