OHIOSCAN
GCRCN
Real quick - I see 30 frequencies for the 1 site you have in Sentinel - you have 15 in yours. A quick cross check to RR and it looks like you have no control channels loaded. The ones in red.
Don't know what happened there, ARC536 has done that before on d/'sl from RR database. i reloaded it again with all 30 freqs the CC is 856.1625 and still picks up nothing.
Also - it's easier if you export as an HPE - that is the standard Sentinel import/export.
i sent the ARC536 file don't use Sentinal
Lat and lon are slightly different - if you use location based, not enough to probably make a diff.
Have the Location settings "off" under Settings. Thanks for the heads up thoguht that might be it but the updated FAV LIST still quite.
Mike
