audio feed ?
bucknut937
Fostoria, ohio
im wondering if there is any way way you can cut the audio from one side of the speaker several feeds i listen to have left side one thing and right side another thing im wondering if there is any way where i can not listen to one side of the feed.
Thanks,
ZAC
dwh367
Owensboro, KY (Daviess County)
Thanks,
ZAC
You can use the balance control listed under "wave" in the Windows volume control settings.
Also, the java player has the option to go left / right. If you are looking for a Windows player, I have released Scanner Force and it includes this feature (Scanner Force). If you go the Scanner Force route, sign up first, then go to the control panel and request a trial key (right now, v1 trial key will last until v2), then download Scanner Force using the key you were issued.
