Audio Issue: Motorola SABER II Model H99SA +060M FID: H44SAJ71139CN
PD47JD
Connecticut
I purchased a Motorola SABER II Model H99SA +060M FID: H44SAJ71139CN No audio. User Display shows the speaker symbol with a line drawn through it. When squelch is disabled via a five second push on the left side control button directly above the PTT, transmission audio is received. Unfortunately, so is all of the squelch hash between received transmissions.
Any suggestions for a fix?
Thank you for your time and and attention to my questions and hopefully a response.
PD47JD
Connecticut
Your response is appreciated. Not an encryption capable unit. It's quite "Vanilla". Thanx!
Oh, I failed to mention. It was receiving transmissions with closed squelch, but then the speaker with a line through it appeared and bingo! No audio.
Also.. I just discovered that in the "Scan" mode, there is no issue in receiving audio. It's an issue (as described above) only when monitoring a single channel.
PD47JD
Connecticut
Meant to say " It was receiving transmissions with OPEN squelch"
a417
verify the programming of that channel personality.
ElroyJetson
Regarding the display icons: Speaker with diagonal line thru it means PL/DPL is active. This is the PL symbol.
Circle with line thru it means the radio is in encrypted mode. Your radio doesn't have encryption but it can still be programmed as if it is an encrypted model, by selecting the appropriate model number and programming the radio with it. Sabers allow that.
in this case it could be programmed as H44QXJ71139CN. This gives you access to the PTT talk tone if you like that in your radio.
It still won't BE encrypted, as there's no encryption hardware in your radio.
If the PL symbol is displayed and you aren't hearing audio unless you press the monitor button, then you have the wrong PL/DPL code programmed in.
PD47JD
Connecticut
Thank you for the response. Much appreciated and quite helpful.
