KD7DDC
Morning, I have two issues with audio using ProScan. My setup is a 436HP with an audio cable connected to a laptop running ProScan on Windows 10. Below are the two issues I am having and need some help with:
1: On the recording, there are stuttering about every 5-10 seconds on a recording. The audio itself is fine (other than issue #2) but there are just dropouts every few seconds. Audio through web/remote feed is stable without the dropouts. Seems to only be on the recordings.
2: On all audio; streams or recording there is a bit of a hiss on the sound that is not present from the scanner itself when not connected to the laptop. It is present with or without any active radio transmissions. I am guessing there are the notch filters but I am an audio noob and have no clue how to use them or any other options to clean up the audio.
