Most of the pro, semi pro and amateur "studio" mixers have way too much going on for what I would like. A simple black 1RU cabinet that has inputs on the back and switches on the front to add or subtract sources, an output control and maybe in the back or even under the hood a small pot that you could fine tune the various input levels. It doesn't need massive transformers on the front of each channel. We are talking amateur communications here not Pentagon approved military or high grade studio commercial gear. Most of us are already listening to signals from a 2-3" poly or paper speaker not aimed at us or even equalized in any way so a mismatch isn't going to bother me any in my radio room. If it had jumper selectable input levels that would be cool.
If you are worried about padding the inputs correctly, places like TecNec and Markertec (Same place) Sweetwater, Guitar Center, etc all have pads you can buy, or you can look them up online and build them yourselves easily. These aren't 2kw RF tuning circuit components, they are for audio levels and SMD components should be fine.
By the way, if you really want the confusing "solo" function, Mackie boards have that as well as most others at this point. That little blinking solo light confuses more amateur studio recordists than anything else.
Sean
Ex television studio engineer (NBC/GE OnO)
34th market, 16 years
