Audio patch pannel for multiple scanners
danesgs
Leesburg VA
Is there an off the shelf solution for running audio from mutiple scanners to a box that has buttons or switches to switch between multiple scanners? Yeah I could build one but don't have the time. Not looking for signal prcessing, just audio distribution.
KJ4DGE
bb911
Southern California
There's an off my shelf solution that I bought at a thrift shop. Someone made a beautiful box with 3 switches, 2 inputs and 6 outputs. I'd have to check, but as I recall you can output A (3), B (3), or A and B (6). Solder joints look great. The connectors are 3 pin plastic xlr. I'll get back here later today with details.
majoco
Stirrer
New Zealand
I have 8 radios which could all be going at the same time and I can select any or all through an 8 channel Behringer RX1602 line mixer. It may be a little expensive but it's just great. Every input has it's own gain and balance control, stereo output, recorder output, headphone socket with it's own amplifier and control so you don't change the recording levels. You probably couldn't build it at the price.
danesgs
Leesburg VA
I thought about a mixer also but don't want to spend that kind of money. Just looking to re-direct audio. Am sure perhaps my next step is a music store or home brew. Remember when the Grateful Dead use to carry a semi-truck full of audio gear, speakers, mixers, baffles and such, cause they would play venues that had less than perfect sound qualities? Not looking for that :)
LATA 722
A simple patch panel might be a good solution.
You can get keystone style jacks with RCA connectors and mount them on a rack mount panel. Using patch cords you can route anyway you want cheap and easy.
Back in my college years when I worked in tv production, we had lots of them. We had them for video, using BNC connectors on the back and patch cables on the front. For audio we had some that were 1/4 RTS and some with RCA connectors. Made life really easy.
n5ims
You could easily make (or buy --> Neutrik NYS-SPP-L plus Rean and Behringer 1/4" Patchbays | eBay <--) a patch panel. Just get a bunch of 1/4" stereo audio jacks and wire up them up with the scanner audio on the tip and ring locations (leaving the other as a floating ground). Then make up (or similarly purchase) the patch cords using 1/4" stereo audio plugs wiring the tip to tip, ring to ring, and ground to ground (or to eliminate ground loops if necessary by connecting the ground only on one side). On the jacks, you will connect your scanners on one row and desired output(s) on the other (or however makes sense to you). Patch panels are (or at least were) often used in professional audio settings. Note: If you make your own panel and cords, you can use whatever size stereo jacks and plugs you want. Using 1/8" jacks will allow you to use premade 1/8" stereo patch cables that are available most anywhere (also the panel size will be smaller, which is often a plus!)
Be aware that using the stereo jacks are there to isolate the two audio lines and are designed for mono use. For true stereo use, you'd use a pair of jacks (one for left and the other for right). They are designed for balanced audio. For unbalanced audio, you could use mono jacks but that would force a common ground and could cause issues if your sound source isn't designed to work with common grounds. Also, since most scanners use the external speaker jack it will be unbalanced audio and may expect a speaker or other load to be present at all times. You can fix this using an audio transformer to both provide the load and convert from unbalanced to balanced audio lines. Some radios are designed so their audio must be isolated from ground to prevent damage to the audio circuits. These will need to be wired using balanced circuits! You may still need the transformer to fix the impedance issues though.
A typical 8 ohm (or whatever fits your input/output) to 600 ohm transformer should work fine. Just make sure that the 8 ohm side is on the scanner side and the 600 ohm side is on the jack side. For your outputs, this would still be similar, with the 600 ohm side still on the jack side and the 8 ohm side on your output device side (note, this assumes both your input and outputs are 8 ohms. If your output device isn't 8 ohms you should use different transformers for the outputs.
