Audio quality level - APCO decoder
brockd
I'm having problems I think with the APCO card installed on my digital scanner. I tried setting the audio quality level so I can hear the radio system signal clearly without garble noises. It comes through ok but, there is still a lot of garble/distortion while listening. I keep trying to lower and raise the audio quality level to get the signal below 50 as indicted in Uniden's manuel without much luck. Audio quality indictor seems to vary continuously up and down, going from 40 to 160 when the system is active. Could someone please help me. I don't really want hear any garble while listening.
I have a BC-785D scanner with a digital decoder card installed and referring to a mixed mode VHF Motorola Smartzone Type II system.
Thanks.
David
jpm
Hey cowboy dude and the others with the audio issue. I had the same issue but I had inside information that the digital system I monitor had problems. one improvement they replaced a tower. motorola has done a excellant job with the system and on all my digital unidens Northwest central dispatch here in illinois sounds great on them. moro of the story have your facts straight before blaming a scanner. In fact all my uniden digital scanners have the default setting on the audio adjustments. so make sure the system your monitoring isn't the issue first as i knew about the system i monitor..
