Here’s the problem: I’m trying to stream 2 scanners using 2 separate (but identical) usb sound cards on one machine. When I tell the app to use the system (windows 10) default sound input, everything runs fine, but if I tell it which of the two to use, it runs fine for a few minutes then starts repeating a 3 second loop (even the audio level indicators show the audio Level coming in still, even after killing the source). Any idea or advice?
the system is a virtual machine running windows 10 inside ESXi with a passed through usb3 controller (no problems there) with 2 GB of memory (this VM only runs radiofeed).
