Austin Condor :BNC wear?
nwiscan
Northwest Indiana
Hi
I recently picked up an Austin Condor antenna and am still getting use to its large design. Although I cannot make any claims yet about its efficiency I did have one immediate concern.
Do you think the flexible nature and the additional weight of this antenna causes wear to a scanner BNC connector?
Rt169Radio
CT
Well if it is indeed top heavy then there is chance of BNC wear,but I wouldn't worry about it.I don't think they would make a handheld scanner so heavy as to cause BNC wear.
K9WG
Greenfield, Indiana USA
Probably have more wear putting on and removing then from weight. I had a 2-meter handheld that I used with a mobile antenna and wore the ears off of the radio's BNC.
LtDoc
Oklahoma
A BNC connector just isn't the strongest type connector around. So, with reasonable care it should last longer than the radio will, maybe (who keeps the same radio for ever?).
- 'Doc
