Austin Condor
W4KRR
Coconut Creek, FL
_DeS_ said:
Hey Guys,
Anyone use the Austin Condor Multiband Portable Antenna ? I'm probably going to buy one for my Pro-97 & was curious how other users faired out with it.
Thanks...
It does work very well as an all band scanner antenna. However, it's 13" long and kind of fat, so it may look kind of strange on a scanner when worn on your belt or hand carried. This may or may not be an issue with you.
_DeS_
Cape Breton Regional Municipality
Thanks for the info. As far as look and what not thats not an issue, it will only be in my car or on my desktop. So from what I gather this antenna will improve my reception over my original RS stock antenna ?
Colin9690
Delaware County
Lewis Center, OH
That is correct. :)
John_M
Rochester, N.Y.
Yes, it will improve reception over the RS stock antenna. Another handheld antenna you may want to consider is the Diamond RH771.
http://www.diamond-ant.jp/ama2/eng_ama_2_3_2.asp
